Yes both forward and reverse . Pressure was checked as far as I am aware , bad memory now , brakes checked too , once it cools down it will run ok again until warm ! Sorry about the extremely late reply !!! I couldn’t remember my log in infoBoth forward and reverse? Has charge pressure been checked?
Hi Omal,I have a similar problem with a bomag ad3 , when hot , 20-30mins or so it’s almost like it looses pressure on the oil , if you vibrate yourself into a rut it won’t pull itself out of it , any uphill resistance against the machine driving will stop it suddenly ,
No, they cannot be adjusted. Your issue is most likely electrical.MG2361, I have the same problem as Omal and Zach. Mine definitely has to do with the brakes. You can hear them dragging. It is almost like the brake solinoid can't hold the valve open when it gets warm. Can the brakes be manually adjusted? What was the charge pressure you were referring to above? Any help might fix all our issues.
The seat switch is actually mounted within or outside underneath the seat cushion.I assume the seat switch is the seat belt?
A 12 volt test light will tell you if you have power to the park brake solenoid. You could also measure with a volt/ multimeter.If I install a jumper from the battery to the solenoid after removing the original wire, should this act as a test on the solenoid?
There is a removable panel, right side underfloor level. There should be marked test ports there and charge pressure will be one of them.how do I test the charge pressure?
YesIs this a hydraulic charge pressure?
0-600 psi for charge pressure only. Don't use that gauge for any other pressure measurement. I don't remember the exact spec on the charge pressure but it seems like it was in the 400's. The charge pressure should remain steady at idle and full throttle. It should remain steady when you engage forward or reverse. If it drops when you try to move the machine, then you are losing pressure in the travel loop which is going to case drain. That in turn will let the brake springs start to apply because of the pressure loss.What type of gauge will I need?
CorrectJust verification that original systems are functioning?
I don't think it is anything special. You might pull off the solenoid coil and check it for a part number. If you find a part number, google it.If the solenoid is defective, do you know where to purchase one?
