BOBCAT320 CONTROLS FOR BOOM BUCKET SWIVEL
scottstrcking
ohio
HELP PLEASE! After brazing the hyd.cooler my controls quit working.is there a way to bleed the system? my tracks and blade work but cant get the hand controls to work,the fuses and safety switch are all good.they worked fine up until the second time brazing the cooler.any input would be Appreciated.
Whelp, need to figure out how brazing it, could affect those functions.
Knowing full well, braze runs like water, if you get it too hot.
Hopefully, it is nothing internal but I wouldn’t expect there to be, with some functions working.
You could try putting a little pressure on the tank but generally not necessary.
What condition is the filter in and is it possible you shut something off before brazing it?
scottstrcking
ohio
i rinsed out the cooler and it was only a pin hole,i changed the filter,and to applyed pressure to the tank,my up and down boom was working so i know the safetys are good plus i checked them anyway,then i took the cooler off again it was still leaking when i put it back on the up and down quit working to.all the fuses are good to.
Simon C
Heavy Equipment Mechanic
Try cracking the line after the pilot filter and wrap with a rag and tape. Put air to the tank while starting and oil should immediately come out onto the rag. Must be air locked somewhere, try it further down the line. If pilot circuit is air locked the main control will do nothing.
Simon C
scottstrcking
ohio
Simon C
im trying to find the pilot filter its a older machine the only thing that looks like it might be some sort of filter is in the picture,i still tried pushing air thru the hyd.tank while running it but nothing.20250329_133714.jpg
That looks like an accumulator not a filter.
You may have a solenoid controlled valve stopping oil circulation.
Are there any coils you energize to get boom hydraulics, I would start there.
Simon C
That is an accumulator as HarleyHappy said. You will be looking for a small pump with a line going to a small filter. Might be running off the engine gear train if not off the flywheel. Could be piggy backed on another pump. An operators manual would show the filter.
Simon C
Kobe Steel
Here are some parts diagrams off the bobcat website that may be of some help.
I believe the solenoid in your pic next to the accumulator is the pilot lockout solenoid so it is worth checking this out both electrically and mechanically.
Best regards
  • Hydraulic Circuitry (Joystick Controls) (Standard)_320.pdf
  • Accumulator Valve_320.pdf
  • Hydraulic Circuitry (Pump to Valve to Cooler to Filter)_320.pdf
scottstrcking
ohio
Best regards
I appreciate the help I've been looking for the schematics on this And this helps out . I tested the solenoid with a test light And it's getting power next I guess I'm gonna try to pull it off. Thanks again I will get back to you let you know what happens.
Kobe Steel
im about to give up and take it to a shop ive tried everything still nothing
Give us a run down of what you have tested and tried so far.
Lots of old school mechanics on this forum that have years of experience in troubleshooting these sorts of problems and its that type knowledge you wont always find in a workshop manual or in some cases even a workshop so don't give up just yet.
Best regards
