colson04
Finally pulled the Bobcat into the heated shop for some long overdue maintenance. Threw the fan belt last week, found the tensioner has failed.
While in the shop, I thought I'd address an engine oil leak. Now I'll be replacing: fan belt, drive belt, alternator belt, fan drive pulley (its bent), the fan tensioner, the main drive tensioner, the idler pulley, all filters, 2 hydraulic hoses from under the hydraulic tank, and adjusting the steering as the left side has considerably more slop than the right side. To address some of the leaks, the engine has to come out, so I started disconnecting everything so I can pull the engine and pump together. Once out, I'm also going to pull the fan drive and reseal it as it appears to be seeping gear oil too.
If it hadn't been below freezing when I started, I would have power washed it before bringing it inside. The layer of grease, grime, and oil is really heavy in the belly of this ol girl. She's a Series C with 3200 hours on it.
![20230217_125121.jpg 20230217_125121.jpg](https://www.heavyequipmentforums.com/data/attachments/264/264627-99ffeda972bddc015f10f05f7aec01b0.jpg)
![20230217_125135.jpg 20230217_125135.jpg](https://www.heavyequipmentforums.com/data/attachments/264/264628-f590ba787b1161af96da4897f42e5407.jpg)
