Ricardo Cotte
Hello all,
I am in need to replace my auxiliary hydraulic lines going to the extend a hoe.
I was planning on having these made before disassembling and already know the fitting size/type going to the quick connectors.
However, the other end that goes in the pipe running along the boom I have not been able to see it because I am lacking a good 35 mm wrench to loosen the connection. The fixed end on this hose accepts a 32 mm spanner.
If I could determine this I can have the hoses made in advance. Just trying to gain some time here. Part no is AT308466 and my local JD dealer doesn't have any. Was to told to fabricate them.
So, it's either buying a 35 mm (1 3/8") in a rush or letting the good friends here at HEF help with their experience. Thanks for your help.![P_20240625_111004.jpg P_20240625_111004.jpg](https://www.heavyequipmentforums.com/data/attachments/299/299378-6de477f98671baeb36d80ffd7596bca6.jpg)
