paul croxson
australia
Hi all, doing a bit of road work with dozer blade, engine started to run a bit rough, parked it up, noticed a diesel leak. Seems to be from the engine side of injector. Have posted a few photos, did have a video but can’t upload hopefully someone has an idea why and how to rectify.
really hoping injector isn’t stuffed
thanks in advance
paul
thepumpguysc
Sunny South Carolina
Master Inj.Pump rebuilder
Do u mean inj PUMP.??
All ur pics are of the pump..
Is it coming from the little hole by the name plate.??
If yes, that’s a “weep hole” telling u the front seals in the pump are getting ready to let go and fill the crankcase up with fuel..
paul croxson
australia
Hey, pump guy, yes forgot to add pump into thread.
yes looks like coming from sheep holes.
how long until they give way completely?
big job to get pump out? Will they be special seals or generic?
cheers
thepumpguysc
They are specific..
No telling how long before they fill the oil pan with fuel..
Do u have a fuel shop close by that u use.??
paul croxson
australia
Fuel shop? Sorry lost in translation a bit in australia.
service station for fuel, or someone like a diesel mechanic?
we are in rural australia, was hoping to pull it off myself.
thanks
paul
thepumpguysc
A fuel injection shop is a bunch of guys that rebuild injection pumps..
There is a name plate on the pump.. I need those numbers to look up the seals..
paul croxson
australia
No, not close, will be a drive away.
hard to pull out? Was hoping to do that and take it somewhere if required or just do seals myself.
thanks, appreciate your help
thepumpguysc
The pump drive is NOT KEYED, therefore, when u pop the gear off the front, u lose your timing..
U have to lock the pump with the bolt on the side of the pump..& u can’t loosen it until the pump is put back on the engine a tightened back up.
thepumpguysc
The seal # is Delphi 7174-856 you need 2..
Pay attention to how they come out..so u can put them back in the correct orientation..
Good luck
paul croxson
australia
Good luck
Great, thanks very much for your help.
think I will need to try and pull it out myself, as we are having a horror year on the farm. Only getting paid 50% for what it costs to produce our crop.
‘would you have the time to explain better bolt location and best directions for removal.
thanks
paul
