I have been called out twice on 2 separate JD 85G's both with similar problems. The first one would start and run for about 100ft then shutdown showing low oil pressure and low voltage. The second one won't start and shows low oil pressure and low voltage. I was able to start it for about 1min twice, but shutdown showing both low. The interesting part is that it is not showing any codes.
Any help or suggestions in this matter would be greatly appreciated.
