It sounds like a starter issue. Removing the starter may help diagnosis. Check for power and ground connections before removing it. Yes, the starter might not be engaging correctly.I have a click sound when I go to start the engine. I thought it was the battery so I changed it. Still clicks.
Should I remove the starter?
Is the starter not engaging?
