580n 4030 fault code
Will580n
Toledo
He, everyone Thanks for this awesome site, im trying to fix this trouble on 2010 super n case 580, a stop light Is on, at same time a gear logo is on display, trouble codes displayed área 4030, 4031 and 1021..anyone knows about this CODES. Thanks for your help.
laycobeau
Tulsa Ok. [email protected]
Lead electronic technician
1020
Transmission oil temperature entered red
zone on gauge.
1021 Fuel temperature too high. Check fuel level. 4030 and 4031 rev and nut and fwd and nut at same time sounds like wiring problem??? chafed at corners????
Will580n
Toledo
Thank you for your help sir, I took a pair of pics I hope can fix this because I can't find nothing about this issue, wiring harness looks fine, all levels are ok. Any advice??
4030 code still on my diag screen.... Ay each time I try go Rwd or FWD..
laycobeau
Check your wiring from your shift lever to your TCU should be a 5" x 8" x 2" give or take maybe under the seat. If wiring not bad may be your shift lever
Hope some one has wiring prints that can help you.
Will580n
Toledo
Guess all connections are good, did you know that gear on display means? Or 4030 fault code.., thank you so much for your help...
Will580n
Toledo
Seems problem is inside of shifter lever, because a little metal piece is destroyed guess it's making short-circuit, TCU reads many functions at time.. do you have any idea where i can buy this shifter lever..?? eBay??
Will580n
Toledo
580n fixed already, thank you for the support, manuals, diagnostics and advices.. I changed an used shifter and now it's working perfectly, so thank you again..
