3406b shrapnel!
Tyler d4c
Salix Pa
Showed up with a slight knock listening with a screw driver sounded like number 4. Bottom end looks good. Valves have about 60 thou lash across the board. Lifter clips are all in place And found these goodies.
Could my knock sounds be absurd valve lash and these be for the compressor.
7fb51091
Odd looking pieces --.015-.030 lash, what's cylinder liner, piston skirt like?
Tyler d4c
Salix Pa
Exhaust all are 60 plus I just checked the intakes there all 18 ish. As for the advance I haven't pulled the cover but on a parts diagram I can't pick out anything that is needle bearing like
Tyler d4c
Salix Pa
It doesn't explain your #4 knock though. Gear train would've been across the board.
On it doesn't but does the loose exhaust valves explain it im calling a knock but to a different ear I may have a different discrimination I'm half convinced to put it together and do the valves up and see what happens
funwithfuel
Will county Illinois
Mechanic
As long as you don't have a pan full of powdered metal, I would. Did you kill cylinders while running or just the stethoscope thing?
Tyler d4c
Salix Pa
Just listened to it didn't think to bust the lines before I pulled it apart there's some what looks like aluminum from a aluminum connecting rod failing but not much and a few small stones someone dumped in I may just pull the come yet one more gasket done mean anything
