210le stop light flashing
Dans210
Nipomo Ca
First post ever anywhere so here goes. I have a new to me 210le TO210LE883322 and the stop light and alarm have 32 88 33 code which I believe is no codes found. I have un plugged the jumper wire and no change. I used my code reader and no current codes. The switches on the dash were rough so I replace them all: ignition,mfwd,turn signal, lights and the starter relay because of corrosion. I replaced the monitor and tested the three relays along with the fuses. All the lights work the neutral buttons work on the shifter and loader control. When I had it delivered we struggled to get it to move off the trailer but rocking the park brake switch it finally moved so I replaced it as well. I’ve read about the timer relay but I don’t believe mine has one. Any ideas?
