Brendananderson21
Hey, im new to skid steers I just picked up a cat 289d with 1500hrs about a month ago. Was doing gravel and noticed a couple hrs in it starts to bog down when turning or moving forward. Once I let let go rpm come back up doesn’t do it all the time but frequently when hot. Was wondering if it could be a drive issue or fuel issue not sure if it’s happened to anyone else. i plan on draining drive oil and putting new oil in and possible draining fuel tank to put fresh fuel in. This doesn’t happen when everything is cold only anfter a couple hours of running. Also if I take oil cap off there is pressure coming out no smoke a vapor anywhere put pressure is this normal. If I rest cap on it without screwing it in it bounces around but usually stays without falling. Checked dipstick no pressure vapor or smoke coming out of there. Motor runs good no diesel in oil or anything. Thanks for help!
