2013 New Holland C238
Mike Grunloh
Jackson
This thing is making me crazy.
2013, cabbed ac/heat, hi flow
Was running fine, parked it, next time the thing is dead as a hammer.
put in new battery, replaced front relays (7 of them), all front mini fuses.
won’t power on unless you are in the seat, when you do, the power button, operate, start, and auxiliary lights come on. Machine won’t try to start. Occasionally get the glow plug light to come on.
9152, 9153, 1051, 1909, 1906 Are the codes I’m getting
borrowed a dash unit, getting same thing
lights, wipers, etc… I get nothing
had a guy with the software hook up and can talk to the ucm but can’t get anything out of the Ecm.
Finally got the grapple off it yesterday, but still need to crack hydro lines and get the boom up so I can get under the cab.
this thing is dead in the field and I’m going to have to figure out how to get it on a trailer and to a shop unless I can get it fixed
any ideas???
Farmerbob101
Ohio
I have a nh l218
Dead from one day to the next
New battery, seat switch works fuses and relays good, no power to instrument cluster.
what did you find on yours that was causing all your trilouble?
Thanks
