Hi guys, was loading this Genie onto the float this morning, as it was getting up the ramp on an angle, the throttle stopped working and wouldn’t leave idle even when the accelerator was pressed.
Turned the machine on and off and it worked again as normal to get the machine down to flat ground. Get on the angle and it happened again.
We gave it a running start up the ramp and managed to load it. Now on site today, a couple of times the same thing happened while moving around on flat ground. Can only be corrected by turning off and on the machine.
It threw this code the first time, I’m having trouble finding it as it’s not the common format for codes. (PV101 #43)
Any help would be appreciated.
