Tim Modine
View attachment 193561 View attachment 193561 View attachment 193561
old timerHi Tim, if it is the machine era I am thinking about you should be able to see your pump pressures on the display (monitoring section) There should be 2 pumps displayed, check the pressure at bucket relief and stick relief. In regular mode should be 4785 +- 75psi. Make sure you are only operating 1 function at a time! To be certain of the specs, I will need the serial number and i can look it up. P.S. If the display is in BARS 1 bar =14.7 psi.
When operating a single function the pumps should work independently
