I am so sorry, i hadn't noticed you had replied. there isn't really any spec's per say, the following is from Prosis
Manual engagement of the parking brake takes place when the two-position switch SW5501 is activated, which means that a request for engagement of parking brake is sent to the control units V-ECU and T-ECU.
Automatic engagement of the parking brake can take place in case of the following events:
○ The parking brake is always active when the machine is started, regardless of the position of the switch.
○ When the software function Delayed stopis requested.
○ Request for activation of electric parking brake from the function Load and Dump brake.
○ If the brake pressure in the accumulators is Not ok (if pressure has been lower than 2.5 bar for more than 1 second). This also generates an alarm.
For continued engagement of the parking brake machine speed must be below 2 km/h.
In the next step the voltage to solenoid valves MA5501 and MA5502 is cut off from the control units V-ECU and T-ECU, respectively. This means that the air to the parking brake's pneumatic system is drained, and the brake pads are applied against the brake disc by spring force. When the pressure sensor SE5501 indicates low pressure, the parking brake light LC5501 is activated. Then the longitudinal differential lock is activated,
