2000 jcb js330 air compressor using oil
hitmix300
detroit
hello, i bought a 2000 js330 track hoe and noticed i was 2 gallons low on oil after 40 hours of use. i found that the air pump between the timing cover and high pressure mechanical fuel pump is blowing engine oil out of its pressure outlet line and it is filling up the air tank with oil.
does anybody know if i can remove this air pump from the machine or find a rebuild kit for it so i can keep my engine oil, well... in the motor
thank you
