1987 JCB 1400B / tech advice /Operators Manual & Parts Book
vintagecarlover
waverly hall ga
Well hello all. I'm now in the JCB backhoe owners club. Have had old backhoes before but usually old Fords and a Kioti. Machine has 2 cylinders off for repacking so first rule of business is get battery charged and cylinders reinstalled. Then there's a long list but I'd love to acquire the manuals for the 1400b. Pic is for attn.
[email protected] for email. Any insight or suggestions highly welcome and appreciated. I'm a bobcat owner x 4 but don't hold that against me. Lol
casey518
adirondacks ny
May be able to help. What's your machine number? First order is to check/change the hydraulic filter. Many never get changed and end up rupturing, sending all sorts of nasty debris to the pump.
John Fitz
C'dale
I just shared a Google-Drive folder I put together for a chap not long ago. If you have trouble accessing them or need something else that will help, let me know.
rmallow
Enumclaw WA
Good day all,
I have a machine (SN 334036) that I would absolutly love to get any available manuals on. Currently working on a "No Start" issue I beleive to be caused by the start relay not getting full voltage while cranking. Only seeing about 4.5 volts while cranking, on the ignition side of the ignition switch (2 white wires). Any feedback is greatly appreciated.
Thank you,
-Ryan
metty
NC
I would also appreciate access if you dont mind. just picked up a 1400B today that needs some love. my email is jonmetty at gmail dot com
Wilkins
Florida
If you would share the info you have also would be greatly appreciated email is [email protected], 1400b sn339268/7. When I got it it was stuck in 2nd gear we have dropped trans new bearings, clutch pack, shift fork. Now have all gears but very weak in reverse and hydraulics very weak after running 15-20 minutes don’t know where to test hydraulic pressure at? Any suggestions would be appreciated. Thanks John
