So the pressure on the gauge should go UP as the voltage goes DOWN?
I should have 28v no load and theoretically 0v at full stall load?
I will get the stuff at the hydraulic shop to do that test.
Today I was able to see codes on the mpdr. Program Again it had every code imaginable. 10 codes in total. I should have wrote them down, the first code was for one of the pressure sensors, so I reverted back to monitor mode to see if it was working, and it was, then back to the fault codes and they were gone?
I'm wondering if I'm having an issue with the PVC controller communicating the fault codes?
