580 case C adjusting idle
Bill95709
Paradise ca.
I’ve replace the injection pump with a rebuilt one. It wasn’t cheap but it runs good now. I’d like to turn down the
Idle which should be easy but I thought I read something maybe in the manual not to do it on the linkage. Is there some special way to adjust the throttle? Can I just adjust the throttle linkage? I don’t want to screw something up.any advice would be wonderful.
franklin2
Virginia
Here's the info from the manual. Looks like the governor is involved in some of this so be careful.
thepumpguysc
Sunny South Carolina
Master Inj.Pump rebuilder
There’s a screw on the inj pump.. simply loosen the 5/16 nut and use either a screwdriver or a 5/16 nut drive and back it out a tad, until you’re happy..
Bill95709
Paradise ca.
The hand throttle is all the way down. From what the manual says is to use a tachometer. Don’t have one and wouldn’t know where to put it anyway. And if do turn it down should I put lock tight on the stop nut? I’d think my ears would tell me when it’s slow enough.
Ty bill
thepumpguysc
Loctite is by not necessary..
A Photo-tach is a handy tool..
Only costs 20.00 online..
It comes with reflective tape and u stick it on the harmonic balancer.. then pull the trigger on the tach and bob’s your uncle..
If u wanted one for the dash, most of them read off the alternator..??
