Ok back on this thing again. Took pump to a local shop and was torn down and inspected and then bench tested and all is/was well. Reinstalled pump, all new filters and drained diesel tank and replaced all diesel and installed extra inline filter. Bleed all lines and fuel filters and injectors and still won't start. Have tried everything possible and still wont fire up. Pump bled , top and bottom until no more bubbles. Engine turns over and has some black smoke out the stack but just wont start. There is fuel coming out when bleeding injectors. So, bottom line is, does not appear that i had fuel problems in the first place. It must be something mechanical that i am overlooking and MAYBE somebody out there knows what the problem is. At least i am hoping. HELP Please!!
