JohninAK
I need some help diagnosing the RTD solenoid, as I think that's the problem.
I replaced the microswitch mounted on the loader frame, wired it on the NC side of the switch. I have B+ to the blue wire at the switch, continuity to ground on the black wire. I have continuity between the switch and the solenoid wiring, I have 6V at the solenoid, assuming that is due to the resistor in line.
No action at the solenoid when I manually work the switch in KO....?
Assuming the solenoid has failed, any help here?
Thanks, John
Thanks, John
