Allan Neels
I'm looking for the 2 speed line from the final drive motor to the swivel
There are 2 small lines need to identify witch line is the 2 speed line
The 304.5 serial number is #WAK00722 The bottom small line connections on the swivel are the return lines and the top small lines are the 2 speed connections.I'm looking for the 2 speed line from the final drive motor to the swivel
Can you please clarify. Did you replace the motor on the side that was previously slow in reverse and it has made no difference.?I do have another issue the reverse on one side of the machine is very slow, forward works great but reverse is very slow on one side. I was hoping that when I replacing the drive motor that the slow reverse issue be would corrected.
In that case the swivel is the obvious suspect. It may be that the seals on the section that carries the “feed” oil flow to the travel motor when you are in reverse are leaking. When the machine travels in the forward direction that line only carries return oil flow from the motor and so has no real effect on motor performance even if it is leaking internally.I replaced the motor and drive as one unit and the slow reverse problem is still there
On a machine as small as yours access will be the biggest problem. A swivel is easy enough to rebuild but it will have to be removed from the machine and got onto a bench in order to disassemble/reassemble. When I get chance I'll post up a parts list plus the instructions.Can the swivel be repaired in the machine or are rebuild swivels available
See attached. It has the parts list & all the instructions. There is a seal kit available under a single Part NumberI'll post up a parts list plus the instructions.
