Heavy Equipment Forums
Go Back   Heavy Equipment Forums > Compact Equipment > Skid Steers
Reply
Thread Tools Search this Thread Display Modes
Old 11-02-2009, 11:51 PM   #16
Aardvark1
Junior Member
Thank you for the voice of reason. My excavator is rubber tracked and is absolutely useless in the snow and ice. I simply park it until the ground can be seen again.
I had read a little on the OTT setups being used by some posters here. Seems like the biggest complaint was the tracks would fall off. Any thoughts on this concern?
Aardvark1 is offline   Reply With Quote
Old 11-03-2009, 12:05 AM   #17
DeereMan85
Junior Member
It can happen. If you keep your track tensioned properly it's less of a concern. The advantage is that losing a track doesn't mean you're totally immobile.
DeereMan85 is offline   Reply With Quote
Old 11-03-2009, 03:35 PM   #18
mxridernrth
Junior Member
Well I owned a Bobcat 753G that had McLaren steel OTT. They were great for moving dirt, flotation in mud, and increasing stability. The only thing that I found was not so great, was that the added height made grading a bit more difficult because you can't lower the heel of the bucket down far enough so you end up angling the blade downward, and then it digs in easier. Granted I was a real SS noob at the time so my experiences may be skewed.
I have used the Deere 322 CTL quite a bit in everything but snow. I can say that machine has great stability, floats well, and has gobs of power. The cab is kind of cramped mind you. I rent it as needed on jobs and the word from the rental shop is that it has been very reliable with no maintenance required on the undercarriage.
I will say that the style of tracks that you choose makes a huge difference. The standard 'pad' style tracks are great at not chewing up laws (especially when they're worn down) but they don't bite nearly as well as the more aggressive ridged ones like this http://www.mclarenusa.com/nextgen-td...er-tracks.html
mxridernrth is offline   Reply With Quote
Old 11-03-2009, 03:53 PM   #19
DeereMan85
Junior Member
You're definitely right about the track style making a difference on a CTL, although even the McLarens will not do as well in snow as a wheeled machine. I just think that for Aardvark's wide variety of projects the most versatile machine available will suit him best, which in this case is a wheeled skid steer with OTTs. Deere makes a bucket offset adapter to alleviate the bucket height problem you mentioned. I'm sure other manufacturers have a similar kit.
Old 11-03-2009, 03:58 PM   #20
mxridernrth
Junior Member
Quote:
Where were you back then?!!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is Off
HTML code is Off
Forum Jump
Sponsors
Forum Rules
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Site maintained by Ez1 Networks
